Dash Wire Question
Started by JamieZ, October 18, 2014, 11:42:06 AM
JamieZ
I'm trying to figure out where one of the wires on the passenger side of the instrument cluster goes.  When I took the dash out, I put numbers on them all and labelled them.  The wire in question is labelled 84 (looks to be brown/black?/grey? with a tracer) in this picture:
My notes say "Key" but I have no idea where it connects.
Other wires in that group are the multi plug 5 connector for the wipers, the single wire of the wiper (red), 2 wires for the washer (brown),  and the 2 ammeter wires (red and black).
Any help would be appreciated.
moparnation74
I think that goes to your accessory light above your ignition switch, or key light.
JamieZ
I thought that as well, but that is already connected.
That is the yellow wire which connects to a wire that feeds from that silver cylinder relay
Looking at it from the side I just can't see anything that's missing a wire.
Charger-Bodie
JamieZ
Washer takes the 2 brown wires  that are next to it.
Charger-Bodie
do you have 2 or 3 speed wipers?
JamieZ
Switch reads: "High" "." "Off" so I am guessing 2 speed
Charger-Bodie
The wire in question looks brown with a white tracer? If it's a two speed car you will have a wire over there not used.
JamieZ
Yes it's brown with a tracer.  Weird that I labelled it "Key" if it connected to nothing. Thanks for the help!
It's for the 3 speed wiper so it's not connected if you have 2 speed wipers.  Tape it into the harness and ignore.
