360 from hell!!
Started by ionracer24, September 09, 2014, 09:54:15 PM
ionracer24
Ok, i've been a mechanic/computer guru for going on like 20 years.  The other day i bought a plymouth fury III ( yeah i know its not a charger, but i'm desperate.)  It's got a low mileage 360' that is giving me the red u know what.... :flame:  I've quadruple checked timing, it's not 180 out and its got new plugs, wires, points, condenser, cap, rotor, ballast resistor etc.  Has new 2 barrel carb and gets plenty of fuel....and has fire.  It's not blazing blue spark, but seems pretty decent.  It will barely idle and the plugs look black already and if i try to give it gas it dies and pops....Any ideas???  It's literally making me lose sleep trying to figure it out. Any boty have a troublesome 360 also???...HELP!!!! :brickwall: :brickwall:
Real race cars have three pedals......
70 sublime
Has the motor and tranny been apart ?
Is it the original motor and tranny to the car ?
Some small blocks have a special torque convertor that is weighted for motor balance
I had a 318 that ran like crap and that is what it ended up being wrong
Just an idea
redmist
JUNKTRAVELER: all I've seen in this thread is a bunch of bullies and 3 guys that actually give a crap.
Benfro89
Could it be the air gas setup with your carb? Seems like it's getting way to much gas to me  :shruggy:
LOOKING FOR THE ONE :)
ionracer24
i have no idea if its the original engine/trans, it looks like it is, but not sure.  I bought it for like 600 bucks with assurances from my "friend" all it needed was some fine tuning.....i havent been able to time it cause it wont run long enuff no matter if i advance it or retard it... :shruggy:
Indygenerallee
sounds like the Carb needs looked at first to get it idling.
pmike
Plug wires are in correct order?
If you have access to one I say bolt on another carb.  If not then at least rebuild the one you have.
bakerhillpins
Quote from: Dino on September 10, 2014, 07:54:24 AM
:iagree:
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
HPP
Air, fuel, ignition, compression, at the right times in the right amounts. That's all it takes to make an engine run. One or more of these are out of kilter.
Make sure your checking firing order with the right distributor rotation.
Also, didn't early stock 360s have plastic timing gear teeth on the timing set? If few of these get chewed up and your timing will never be right.
Might bring #1 up to TDC, and check where the distributor, crank timing marks, and cam timing are all at in relationship to each other.
el dub
You might want to start with the carb since its running to rich (plugs being the clue) and it floods out when you give it gas.
polywideblock
sounds like the needle and seat is sticking  open
  and 71 GA4  383 magnum  SE
workworkwork
Could there be issues with the valves? Seems odd that the plugs would get blackend just trying to start it. My base model 74 broke a timing chain once and that bent the valves. It was a major repair and had the same symptoms as you.
ionracer24
Thanx for all the tips.  The rotor points right to where it should when its at tdc and the wires are all aligned in the right spots as well, the carb is brand new rebuilt, but i think ya'll might be right with the needle and seat or the float sticking or somethin.  I'll take it off today and tear it apart to see what's goin on if anything.   I'm gonna try a little bit hotter coil too see it that helps.  I appreciate all the help fellas!!   :cheers:
RECHRGD
Check for vacuum leaks as well.......
13.53 @ 105.32
Patronus
My opinion would be to first- confirm its a 360. I hope that doesn't sound stupid, but ya never know. My first guess though would be the timing 180* off. If it won't idle the needle seat could have issues, but it usually does not run at all with that scenario.
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
RGA
Always start with ignition, get good spark at the right time and then start looking at fuel. If needle and seat were sticking it would be flooding out and would be a hard start but would rev up ok. Sounds like timing, maybe jumped a tooth or two, also check for vacuum leaks, maybe old gas ? How long was it sitting. What's compression? What's timing at (should still be able to read it even if it's not running, just cranking) , what's the dwell ?
ionracer24
Tommorow, i'm pullin the timing chain whether  it needs it or not just to be on the safe side, i tried to get to the carb tonight but ended up bbqing instead lol....guess i've had enuff for a few days!! :brickwall:
pmike
Take and post a video  :popcrn: of how it runs, for us to keep making more or less educated guesses :)
ionracer24
I will mike, I'm going to try to get to it 2night.  Its been close to 100 degrees for the past few days and its just too friggin hot to work on it since i dont have a garage at the moment.  I ordered the timing chain yesterday and it came today, so i need to pick it up from stupidzone.  I also have to get the gasket kit from oreilly's since i can never get all the parts from the same parts store... :eek2:  I'm building this car for my son since he wants a classic and the fury's are built like a sherman tank!!
ionracer24
So in the process of taking the front of the engine apart.....one of the long water pump bolts broke... :RantExplode: I'll post a pic tommorow, but luckily it did not break off at the block.  Hopefully with a lil heat and a lil pb blaster, it'll come loose, got another bolt from stupidzone and God willing it'll be runnin tommorow!! :eek2:
Patronus
Let the Pb soak, then give er some heat and the vise-grips. Did you find any damage, teeth, etc?
'08 CRF 450r
'12.5 450SX FE
ionracer24
Soooo, sure as shit it was the timing chain, original aluminum cam gear with that dam bakolite!!  It was like 5 friggin teeth off!!  I dont know how it even attempted to fire....The water pump bolt that broke was litterally fused into the timing cover, weirdest dam thing i've ever seen in my life!!  luckily i was able to get the cover off with a whole lotta pb blaster and a propane torch.  Even so, i had to use a friggin tire iron and a cheater pipe to pry that sob loose and get it free.  The bolt came out with a pipe wrench and some pb also.  So God willing, that rusty, crusty sob will fire and run tommorow..... :eek2:   :smilielol: here's a pic of the front i had more of the bolt and cover but they did not show up so will post those  manana
workworkwork
Hopefully the valves will be ok. If it runs rough after the replacement timing chain you may need to check the valves and see if any are bent or damaged. When my timing chain broke it bent some valves and I had to pull the heads and take them to a machine shop. After the new timing chain and valve work it ran great ever since.
ionracer24
Quote from: workworkwork on September 16, 2014, 11:45:45 PM
I'm really hoping it didn't,  but if it did, at least it'll move under its own power back 2 my driveway
ionracer24
ionracer24
The utter carnage of the bolt fused to the timing cover
workworkwork
OK, so now we are all keeping our fingers crossed for you. Let us know if she is running again.
4cruzin
I live really close to Hell if you want to send it back!   :2thumbs:
Tomorrow is promised to NOBODY . . . .
ionracer24
Ok, so changed timing chain, was off by about 5 teeth, replaced timing chain, still will not run more than 5 seconds and rough at that.  Back firing through carb and doing the exact same thing as before...... :brickwall: :brickwall: :brickwall:  Can the crank be 360 out of phase? i'm at a loss,  :shruggy: :shruggy: i dont know what else to do cept take it apart and rotate the crank
polywideblock
could it be a  bent/stuck valve  :scratchchin:
workworkwork
There is a good chance you have one or more valves that are bent or damaged. You may have to take the heads to a machine shop.
Verify tdc and check the rotor for being correct. Next step will be compression test and or airing cylinders to check for bent valves.
ionracer24
Orrrrrrr i could just drop in the 440 low milage, high nickle content big block i've been saving for a rainy day!!  Yeah, i'm already sicka this piece!!! :slap: thats what i get for buying, with out trying hehe
ionracer24
So the 360 heads are toast and a cylinder wall scratches etc....will post pictures soon.  On the plus side, almost have a 76' 440 running in it now with a 727.  Got pictures of that too, just having email problems but will post it soon.  Things are lookin up finally!!! :brickwall:
workworkwork
Awesome. Sounds like you will be driving her soon.
Quote from: 4cruzin on September 19, 2014, 08:52:24 PM
I've been to Hell and back many times.   :icon_smile_big:
ionracer24
So she cranked up!! No exhaust manifolds, headers, nothin!!  Brap brap brap brap brap.....Was pretty dam awesome seeing 2 foot flames shooting outta the heads!!!  I have a badass set of headman headers that will not fit because of the dam torsion bars.... :brickwall:....Anybody know a remedy??  I dam near sawzalled the dam things out but my freind reminded me what a bitch they are to get back in and out etc..... so needless to say i need to figure out some kind of exhaust system....But it runs now, thank God almighty, it runs.... :punkrocka: :woohoo:
