727, what's this?
Started by Crazy440, August 31, 2014, 08:37:16 AM
Crazy440
Just wondering what the arrow is pointing to, is?
I used to have a handle on life....but it broke off.
70-500-SE-EXPORT
 The kickdown linkage pivot stud attaches there
68 Charger original SS1 paint with matching # 383hp
depending of the year... mine is a full one piece link straight from carb throttle bracket to the kickdown shaft on valve body. No articulated piece ( thanks God )
I thought however it was for the shifter when column shifter cars
Crazy440
So, if you have a manual valve body, should that be plugged?
70-500-SE-EXPORT
Quote from: Crazy440 on August 31, 2014, 05:36:54 PM
Yes, manual valve bodies don't use kickdown.
No need to plug it, it's just a threaded boss with no connection to the inside of the trans.
