1969 Charger Build.
Started by NickJ, July 20, 2014, 08:23:57 AM
pmike
Nice project! Isn't it quite easy to add a sure-grip to an open 8 3/4 rear?
.. Infact if I google "add sure grip to existing  8 3/4", it does seem I remembered right..
NickJ
Yes, it's just a 3rd member swap. Was hoping it was already a Sure Grip. Easier and cheaper that way.  :icon_smile_big:
NickJ
Managed to get the rest of the trunk floor out today although I still need to tackle those damn extensions. I truly feel for you guys that have to do entire floors.. If I see another spot weld I'm going to go crazy!
Stevearino
Everything looks pretty solid. From what I have seen on restoration threads on this site there is isually some work to be done around the base of the wheel tubs. That area looks pretty good.
NickJ
Yeah, They're not too bad. Probably going to replace the bottom 1" or so to be safe.
NickJ
More cutting today. Rotten chunk of quarter and right side trunk extension. Also, managed to clean up the pans for primer. We're getting there. Slow but sure... :2thumbs:
NickJ
Left side extension out today and started grinding spot welds off the frame rails. Hoping to finish cutting and grinding this weekend then weld thru primer and POR-15 next in preparation for welding... We're getting there!  :2thumbs:
NickJ
Finished cutting today. Got a lot of my grinding done and test fitted the pans. Still a little more prep to do including weldable primer and POR-15 but I think they'll be done in about 2 weekends.. Damn job, wish I had more time to work on my girl!  :cheers:
BIGBLCK11
 :2thumbs: Great job!  It's coming along.
NickJ
Hey All,
   Started a restoration page on Facebook if anyone is interested. I'll still be posting updates here since DC.Com is the best resource on the net!
Nick
https://www.facebook.com/Rowdy69Charger
Hemidog
fy469rtse
 :popcrn: lots of work getting done very quickly , pace your self , dont burn out too early.
:2thumbs: walk away when you get frustrated, great car to start with :2thumbs:
NickJ
Thank you!  I'm trying my best to pace myself. I think after I get the trunk floor in I'm going to take a break. Maybe inventory parts and relax for a bit. I'm sure the wife would appreciate it too.  :icon_smile_big:
six-tee-nine
Just a tip : I blasted and epoxy primered the top of the trunk (I mean the underside of the deck filler panel) trough the floor when the trunk floor was out of the way.
I also removed the goop from the quarters with a torch and a putty knife before putting in the new floor.
its alot easier to acces that way.
I went trough this myself earlier this year (also did my lower valance along with the end caps and lower quarter patches).
Its alot of fitting and tweaking but when its in place and you spray the primer on you will feel pretty satisfied.
bill440rt
Doing a fine job there!  :yesnod:  :2thumbs:
NickJ
Thanks for the encouragement and the tips... I've been thinking about it alot since I got the cutting done and I think I'm going to throw the Diff back under her so I can push her out and pressure wash, prep, and prime the whole trunk up to the package tray before welding. Definitely think you're right and it'll be much easier with no floor.   :2thumbs:
You've come a long way in a short time, nice work!
six-tee-nine
Maybe you should build yourself a pair of these body carriers (can Always buy them from US Cartool)
Much easier then putting the leafs and axle under the car
http://store.uscartool.com/mopar-car-moving-wheel-set.html
NickJ
Ronda is back on all 4s in preparation for her bath. Did about 6 hours worth of cutting and grinding today. Should only be a wee bit more than we can clean and prime for welding!  I'm really excited to get these pans in. The first major project is almost complete... Woo Hoo!  :cheers:
Nick
NickJ
Got about 3/4 of the way through mock up. She's coming along nicely.  :cheers:
Nick
keepat
Your trunk floor looks great I'm about to tackle the same project in a few weeks. Good luck and keep the pictures coming!
Pat
six-tee-nine
fits nice  :2thumbs:
Before you tack it in place, make sure to open the hole for the gas filler tube. Its much easier to cut and carfully grind the egdes with the floorpan on the table then in the car with you feet up in the air hanging out of the trunk.
Quote from: six-tee-nine on September 01, 2014, 06:35:11 AM
fits nice  :2thumbs:
It sounds like you found that out the hard way.   :icon_smile_big:
NickJ
Speaking of the holes in the trunk. I had a question I'd like some opinions on. I made a deal with the wife that I'd push the charger into the driveway for the winter (covered of course) so that she could use the garage. Would it be better to leave the pan intact till spring or do you think those holes won't matter?
Thanks!
Nick
I'd leave it.  I don't know why, it's just what I would do. :shruggy:
