cowl foam?
Started by Dreamcar, June 14, 2014, 03:13:29 PM
Dreamcar
I started removing my rusty cowl panel and noticed a foam between the spot welds. What type of foam is this and how do i put some back in when i start plug welding the new panel in? Isn't welding going to burn off whatever i put between the panels?
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
Silver R/T
You want seam sealer not foam, foam absorbs water/keeps moisture and air in resulting in rust. You want to use weld through primer between two panels welded together.
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
I believe the factory may have used some type of weld-through material as I don't see any other way they could have gotten it so thoroughly in between panels. Of course, they were using real spot welders too (probably a lot less localized heat than plug welds). I am using Picklex on the bare metal in the weld, epoxy primer (loaded up to flow into the seams), self leveling 2 part seam sealer (2 part foam if the gap is large), and then brushable seam sealer on top. I doubt it will leak or rust in my lifetime.
Dreamcar
I think I'm going to use Chassis Saver (think POR-15) on the bare metal on the plenum before the newcowl is installed on top, and of course some weld-thru primer on the edges where the new panel and plenum are welded together by plug welds. Then, I'll use seam sealer on the outside edges.
Dreamcar
