Gears for 11-14 rt
Started by Joshua370, June 05, 2014, 03:49:29 PM
Joshua370
Where can I buy 3.73s or 3.93s for a 2014 rt? I'm having trouble finding them on google search
Cooter
May not be available. Remember, swapping gears ain't as easy as it once was. Those new 6,7,8,9, speed autos will not like it.
Joshua370
It's available, the dealer wants 899 for the 3.93 with LSD and 1800 for the gears plus axle upgrade. I was just wondering if anybody knew a web site I can but them for cheaper
Cooter
May not be available from the aftermarket yet I should say....
Quote from: Joshua370 on June 05, 2014, 05:45:57 PM
Honestly, I don't think that sounds like a terrible price - and I fully expect overpriced parts at the dealer! Several places I found are basically just reselling the factory parts at a slight discount. Like this one (2014 is listed in the drop down menu):
http://www.speedlogixstore.com/product-p/bmcp-373lsd.htm
There are certain dealerships that will give you a much better price than the list.
As usual, your bet bet (cost wise) is to source one from a junkyard - although that's hard to do considering the number of cars that had those gears from the factory and the newness of it all. I don't believe that exact rear axle is new though. Try researching that to see if other years are compatible and it will really open up your options.
