Tire size help
Started by keith88, May 23, 2014, 08:42:29 PM
keith88
Hi everybody I have a 69 charger and I will be buying tires soon and i am torn between 2 different sizes that i keep going back and forth on them, they are 235/70/15 and 245/60/15 if you have either i would like to see photos of your car to see what it looks like. Any photos you can post would be greatly appreciated thanks!
1969 Charger  Orange /black top  (1989) 360 engine stock with added xtreme comp cam and a 4 bbl  , 904 trans/shift kit , 8-1/4 rear.. with general lee accents.
twodko
If these will be on all four corners of your car go with the 245's. They will look better and fill the wheel wells more.
I have 235's in the front, they look OK but are a bit skinny.
comet_666
These are 235/60/15 on front and 295/50/15 rear. 7 inch rim up front and 8.5 in rear.
I went around and around on rims and tires myself, was going to go the smaller size your looking at but landed on these.
comet_666
Better shot, kind of.
comet_666
And a rear shot.
Quote from: comet_666 on May 24, 2014, 04:33:49 PM
:2thumbs: :coolgleamA:  looks mean
have a look & read here K88  , lot of interesting wheel & tire combos  :yesnod:
http://www.dodgecharger.com/forum/index.php/topic,63191.0.html
Much depends on the stance you're after.  Level, rear up in the air?  Look at the tire heights.  http://www.jekylhyderacing.com/HeightofTires.htm
I have 245/45/17 on the front and 275/50 on the back to give me the stance I want.  Compare those heights to the tires you are considering to get a better idea.
235/70/15 is 28" tall which is a bit taller than my rear tire.
Mopar Nut
Quote from: Dino on May 24, 2014, 07:39:45 PM
Looks nice!   :drool5:
Quote from: Mopar Nut on May 25, 2014, 01:00:15 AM
Thanks!
:yesnod:
  :2thumbs: :coolgleamA:  :drool5:  love the last picture (4) :coolgleamA:  looks mean
keith88
I have also added 255/60/15 in the mix to anyone had any issues in the front using these.
 have 255 / 60 / 15  on all four corners with a 15x8 wheel with 4 inch back space ,  info on mine in the link I posted  :yesnod:
went with 4inch back space , wanted the deep dish look
keith88
Thanks putting them on 15x7 new vectors - no off set
keith88
OK after doing loads of research and surfing the web and seeing pictures, Im thinking 235/60/15 in front and 255/60/15 rear. I have to keep in mind that i have a 318 in my charger to.
255's are pushing it on a 7" rim in my opinion. While they will mount fine, they will be pulling the sidewalls in, thus reducing their cornering ability. The 235's will fit nicely on a 7" rim. Fwiw, i run 245/60 on the front with 8.5" rims and 275/60 in the rear on 8.5" rims.
keith88
Ended up ordering 235/60/15 for the front and 255/60/15 for the rear And that is the biggest tire that the manufacture says will fit on a 15x7 rim , should have them for Sat.
Mopar Nut
Quote from: keith88 on May 27, 2014, 05:28:19 PM
:woohoo:
crj1968
Man Dino, that last picture is poster worthy- awesome looking car.
Keith- looking forward to seeing this new tire combo.
keith88
This is the results of the new tires got them last weekend.
68 RT
Looks good! Nice looking 69!  :2thumbs:
lukedukem
i put 275/60 on my back rims (american racing vectors) and they are 5x7's. thought they where 5x8, but i checked the other day. is that bad?
luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
keith88
The factory says nothing bigger than 255 on a 7" rim that is why i stopped at that size. Not sure what can happen if it bigger but im guessing its not good.
Quote from: lukedukem on June 10, 2014, 01:03:22 PM
luke
The sidewalls will be pulled in, reducing strength and cornering ability. It will also pull the outer edges of the tread in. I doubt it will cause any nkticable problems for you.
charge69
Great looking '69 and a good choice in tire size. You should have no problems with rubbing in cornering or otherwise with them. :2thumbs:
In case you are wondering, my Charger has 225/70/15 fronts and 275/60/15 rear tires installed with absolutely no problems. Both are almost the same diameter and look "right" on it.
xoman60
Nice cars Charge69 and Keith88. I think mine has the same size as yours charge69. My fronts might be 235 though. I can t remember.
charge69
Beautiful Charger, xoman60!  I cannot tell your front size from the picture.  I forgot to mention my wheel sizes.  They are 15x7" front and 15x8" rear. My tires are just a little less than an inch taller than the stock tires but fill the wheel well nicely. My Charger came from the factory with f70-15 Redline Firestone Wide Ovals according to the build sheet.
I have a set of repro redline wide ovals already mounted on the original wheels but I like the "day two" look of the Cragars with larger meats on it!  I will get around to taking a picture with the original wheels and wheel covers installed soon!
crj1968
looks good Keith. Nice looking car !   :2thumbs:
Mopar Nut
Beautiful looking cars and wheels guys.   :2thumbs:
fy469rtse
Keith, that car has come a long way in a short time , looks great  :2thumbs:
Hope most issues are sorted now and your enjoying it more
keith88
Thanks I an diffidently gaining on it, Just put in a new brake booster and master have a bumper now to install out front and a GL (Narrow version) push bar on the way after i repaint the grill and install the new bumper. And i have made 2 cruise so far this year. :cheers:
