Resister question
Started by keith88, May 12, 2014, 04:42:26 AM
keith88
Have a 69 charger that I just bought someone changed over to electronic ignition.  I am doing a tune up on it and I bought a new coil that comes with a new Ballast resister. But yet i see that the electric ignition comes with one when you buy it as well ,which one should i use the one with the coil or the one that is on it for the ignition?
1969 Charger  Orange /black top  (1989) 360 engine stock with added xtreme comp cam and a 4 bbl  , 904 trans/shift kit , 8-1/4 rear.. with general lee accents.
fy469rtse
Keep it simple Keith, use what comes with , you've got the parts , just change them out , keep as set
Your getting a lot done in a short amount of time to this car
keith88
Thanks its been a long time since i had one of these(30yrs) and a lot had changed when i had my 70 they did not have a conversion kit for the ignition. I bought a 2 wire ready to run distributor (procomp) and could not get it to work ..piece of sh--  than realized that i had the conversion kit in it already so im sending the 2 wire back and putting what i had in it back in and buying a tuneup kit for it ,cap rotor ,coil and wires.
Whats the ohm rating of the two resistors?
keith88
I do not know one of them is on the car the other that comes with the coil has not arrived in the mail yet. How can i tell i dont see any marking on the one i have.
Pete in NH
Is the electronic ignition system you are using the stock Chrysler or Mopar Performance Orange box system?
You have to measure the resistance value with a good ohm meter. Most low cost digital meters don't do well measuring such low value resistors. The Orange Box system ballast resistor is 1 to 1.2 ohms. To keep everyone confused none of these resistors are marked as to value.
keith88
It is the orange box system I dont have a meter.
Electronic ignition uses a different ballast so use that one.
keith88
So if i need a new one what should i buy? To tell you the truth seeing that i just bought this car and im finding a lot of thing that aint right already it might not hurt to buy another right one now!
is it 4 pin or 5 pin box?
4 pin uses 2 prong resistor, 5 pin uses 4 prong resistor
the resistor just drops voltage to the coil, not the ECU
keith88
Pete in NH
The Orange Box system uses a 1 ohm resistor. I think the Mopar # is P5266436.
keith88
I found a site on the web that gave the part numbers for the pieces used on the kit and it listed this part #2275590 for the resistor,so i ordered another just in case.
keith88
I just found another site that lists your number you posted to now im confused. :scratchchin:
Pete in NH
Chrysler is dropping and changing part numbers left and right these days. You can likely get a ballast resistor at your local auto parts store. You want a 1 to 1.25 ohm 2 pin resistor.
keith88
I already order 1 from online using that number i posted but it did not tell me what the ohm was ill have to see if i can find out.
keith88
Just found out its .8 ohm is it close enough or should i send it back.
