Hydratech Issue
Started by charlie45, May 12, 2014, 04:11:53 AM
charlie45
Hello,
my mechanic just installed the Hydratech unit for my Charger, and unfortunately the steering pulls to the left now. There is a brand new Firm Feel Stage II box in the car, and this was not happening before the Hydratech unit.
Any help in trouble-shooting would be appreciated...
fy469rtse
Easy one , go read your factory manual , take it back to your mechanic, top line fitting is the actual valve, you can loosen it with car up just off the ground so wheels aren't touching , engine running for pressure to box , that top valve part of box , tap it up or down to centre wheels , it will seep a little so be prepared to clean up a little
charlie45
Quote from: fy469rtse on May 12, 2014, 04:19:27 AM
okay, thanks. I believe this is the spool valve you are referring to, right? Matt, over firm feel gave me a similar answer in regard to this issue. Will relay this to my mechanic and keep you posted on how it works out.
Thanks.
fy469rtse
Oops forgot to tell you that you need to undo bolts, just crack the tension to bolts that hold it on , just enough that you can see a bit of seepage or that you can tap it up or down, get that valve in the right spot wheels will point straight ahead under pressure, good luck with it , just a bit messy, I think factory supplier set this up on a bench long before its installed ,
