hood spring
Started by el dub, May 08, 2014, 02:50:11 PM
Hard Charger
Quote from: bill440rt on May 13, 2014, 07:15:21 AM
I used a plastic cap from an old Kodak 35mm film canister. They are gray, about 1" in diameter. Seemed to do the trick also, fit on the spring perfect.  :yesnod:
The adhesive plastic film also works, look under the hoods/trunks of some newer cars and you'll see them.
If you can install it w/o bubbles it is practically invisible. works great on my Challenger with a lift off hood. I placed some plastic on the cowl so if I need to look under the hood quick I do not need to get help lifting it off.
el dub
Thanks for the ideas. :cheers:
