hood spring
Started by el dub, May 08, 2014, 02:50:11 PM
el dub
Is there supposed to be something on the hood so the spring does not mark it up? thanks. lw
ACUDANUT
Not that I have ever seen.  :scratchchin:
72Charger72
My 73 had padding at one time
Sorry, it just contacts metal to metal there el dub.
el dub
Thanks for the replies. I guess I'll leave it alone. Now I need to find hood insulation?
I use a rubber body plug cut to fit around the spring to avoid hood paint damage
Do you have a pic of that Chris?  I think I understand easily enough but it sounds like something I'd like to do myself so...
Quote from: Ghoste on May 10, 2014, 08:48:13 PM
Not the best one but you get the idea.
I also glued a body plug to the hood area (to cover up previous damage)...
Perfect, thanks!  (tonights project possibly??)
Oh good idea!  Maybe I should coat the hook in rubber as well, with my luck on these things...   :lol:
Quote from: Dino on May 11, 2014, 08:09:08 AM
Nah, I wouldnt.  You want a tight latch with that thing.  Adding a rubber coating might compromise the grip....
Agreed, that secondary latch isn't sometimes referred to as a safety latch for nothing.
I'm kidding on the latch.   ;)
I only said so because I keep hitting my head on that darn thing.
There are people who temporarily put tennis balls on them for that contingency.  ;)
Quote from: Ghoste on May 11, 2014, 01:08:19 PM
Well I think I need to be one of them because I can't seem to remember that thing is there until I slam my head against it again.   :icon_smile_big:
My friend, I do it at least 6 times a year myself.  I fit helps any it seemed to be a lot worse on the fastabck than the 69.  :shruggy:
Hard Charger
I have used adhesive backed clear plastic on spots where there is metal to metal contact such as this. if your careful, it can be installed w/o bubbles.
it is very difficult to see and protects the paint.
1charger69
I dipped the tip in plastikote.....used 3 or 4 applications so it's nice and thick
With black paint though I can probably get away with Chris' idea to use black body plugs. lol
fy469rtse
I put a small piece of vacuum hose to just the little straight top centre of spring, it seems to stop it marking hood
Clever and simple as well.   :yesnod::2thumbs:
Quote from: Ghoste on May 11, 2014, 05:18:56 PM
Really?  Is it lower?  My car's been on jack stands for so long that I haven't come close to that hook, but once it's back on the ground I should probably wear a helmet.   :icon_smile_big:
bill440rt
I used a plastic cap from an old Kodak 35mm film canister. They are gray, about 1" in diameter. Seemed to do the trick also, fit on the spring perfect.  :yesnod:
The adhesive plastic film also works, look under the hoods/trunks of some newer cars and you'll see them.
Quote from: Dino on May 13, 2014, 06:51:38 AM
No idea why, I think just coincidence but it sure did crack me more with the old car.
