Modern Bullitt build
keepat
I started on the driveshaft loop/crossmember today. Using a press I oval a 2" section of 6" pipe and hammered the top half to match the shape of the driveshaft tunnel. With the loop clamped in place and using a 15" contour gauge (a must have tool) I made two cardboard pattern for the crossmember. With the cardboard center section of each pattern as wide as the square tubing (2") I was able to lay it over the tubing to get a precise line to cut with the plasma cutter. I still need to make the pattern for inside the tunnel above the loop before I can weld it to the floor.
Pat
472 R/T SE
There's no way I can wait until you're finished before saying anything.  Pat, you have mad skills my friend, incredible!!!   :nana:
Unbelievably impressive.  Super awesome build.   :2thumbs:
keepat
Quote from: 472 R/T SE on January 10, 2016, 07:53:21 PM
Hi Mike, I hope to have the tail pipe from your fathers 77 low rider on my fathers low rider this spring and will send you a picture of the bike when done.
Thank you!
Pat
Quote from: Dino on January 10, 2016, 08:40:44 PM
Thank you Dino!
Pat
WHITE AND RED 69
That's the coolest looking driveshaft loop ever!  :drool5:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
crj1968
 :o   Wow man is this car going to SEMA or what??
Incredible work....I feel really lame when I see such skills on display.    :P
timmycharger
Amazing stuff continuing on here Pat, great job  :2thumbs:
Is that a magnetic Sharpie marker? Cool!  :yesnod:
keepat
Quote from: WHITE AND RED 69 on January 11, 2016, 04:14:46 PM
Thanks Clayton! I'm really happy with how it turned out, And I think it adds a lot of rigidity to the frame considering the modifications I made to the original crossmember.
Pat
Quote from: crj1968 on January 11, 2016, 04:31:10 PM
SEMA would be cool, I doubt that would happen, but if it did I would definitely drive it back home!
Thank you!
Quote from: timmycharger on January 11, 2016, 06:34:37 PM
A magnetic sharpie would really come in handy, but actually I took that photo sideways so that it would have the right perspective. ;-)
Thank you!
Pat
Patronus
I dream sometimes of working like this.
I've worked since I was 14 (45 now) with the passion.
Everyday I learn, "tricks on tricks" as they say..
Great job ol' boy.
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
keepat
Quote from: Patronus on January 11, 2016, 09:27:49 PM
Great job ol' boy.
Thank you sir!
keepat
The drive shaft loop/crossmember  is made and tack welded in place. Back to the torque boxes.
Pat
Homerr
Not removeable?  Or a section of it?
keepat
Quote from: Homerr on January 13, 2016, 09:04:40 PM
No, it's welded in but I suppose if I ever had to remove I could cut the bottom loop off and fab up one that could be bolted in??
crj1968
Quote from: keepat on January 13, 2016, 09:10:23 PM
I dunno Pat, seems you don't have the skills to fab up something like that.  ;)
1970Moparmann
Patronus
Let's see some of the tools your using. Like the contours of the extended loop, is that all plasma cutter?
Then clean it up with 80g on a 90?
Do you do any leading? I think that's an area I would like to explore more of. I've heard about welding on rolled stock to body lines and then leading it to a point.. stuff like that.  :popcrn:
'08 CRF 450r
'12.5 450SX FE
keepat
Quote from: 1970Moparmann on January 14, 2016, 12:30:48 AM
Very nice Pat... WOW.
Thank you!
Quote from: Patronus on January 14, 2016, 01:23:08 AM
Yes I cut all the metal for the drive shaft loop with the plasma cutter, most of it freehand.
I have used lead on other cars body panels but the drive shaft loop is all steel no lead. After welding the loop/crossmember to the frame rails I think I could pick up the car from the loop.
Thank
Pat
jaak
Very Nice work  :2thumbs:
This thread and Stevearino's SRT Daytona thread are the best on the web.
keepat
Quote from: jaak on January 14, 2016, 08:00:41 PM
Thank you Jason! But Stevearino's Daytona is on another level! His build is awesome!!!
Pat
phantom
This is SEMA material, no doubt  :yesnod:
Whenever i visit this thread, i see new solutions and awesome craftmanship! Wish i had the same skills  :scratchchin:
keepat
Finished up a few details on the front of the frame connectors today. Front torque boxes are next.
Pat
orange383
That's a great way of closing that hole up. I never would have thought of leaving that long tab attached.  Good tip!
Looking forward to seeing how you tackle the torque boxes as I plan to add some to my '68 this year!
keepat
Fit and tack welded the right front torque box. Had to bend the US Car Tool torque box on an angle and added ΒΌ" along the floor side to get a good fit. Both sides will need the same alteration to fit correctly.
Pat
mike69440
Your thread will serve as an excellent documentation record of your project.
Most Restro-Mods decrease the value of the car, as they are either starting from a wrecked hulk, don't turn out desirable or really functional, and are just one person's vision of what a Charger should be.
None of which applies to what you have done.
If you have not already done so, Please make sure you have download and back up this thread on a weekly basis.
I have not seen anything you have done that is not simply outstanding, well thought out and executed, particularly your chassis reinforcements.
If you ever sell, it should be worth big bucks.
However, Don't sell it!
keepat
Quote from: mike69440 on January 25, 2016, 01:41:29 PM
I have not seen anything you have done that is not simply outstanding, well thought out and executed.
Mike,
I have no plans to sell this car so I'm not too worried about what the car will be worth.  You're right about most modified cars not being worth the money put into them, I'm hoping this will be the exception as I plan on keeping the exterior and interior completely original looking other than a very few small details like the wheels and the stance.  Thank you for your kind words and checking out the build.
Pat
