Rocker panel trim
Started by Dreamcar, April 30, 2014, 12:01:53 PM
Dreamcar
I've found repro Plymouth (GTX, RR) rocker panel trim, but are these the same as the ones fitted on Chargers? Would they work?  Does anyone know if Charger specific rocker trim is available?
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
ottawamerc
Do you have a pic I can see if they match up to the ones I have in the shop!
Scott :cheers:
This hobby is more than just our cars, it's the people you get to meet along the way!!!
Dreamcar
70 sublime
Like this ??
ottawamerc
Not the same as mine but mine is a 3rd gen too.
Scott :cheers:
Dreamcar
jaak
I'm not 100% certain, but I think the Plymouth Moldings are different than Dodge Moldings. IIRC correctly Chargers/Coronets used the same moldings... I don't know what the difference is. Another difference you need to be aware of, The clips are different on a Charger, they physically look different. Charger used a different clip than all other b-bodies.
Jason
Dreamcar
Quote from: jaak on April 30, 2014, 09:50:08 PM
Jason
Thanks!!
70 sublime
I have a dead 68 Coronet and it has this trim also
On the Coronet the chrome is different
It has 3 or 4 grooves in it that run the length and I think the clips look different also
Will try to get a picture if it ever stops raining long enough
Dreamcar
Quote from: 70 sublime on May 01, 2014, 07:55:37 AM
Thanks. Its supposed to stop next tuesday i think :shruggy:
