body filler
Started by Sgtmajor, April 11, 2014, 06:21:14 PM
Sgtmajor
Is there a body filler beside Bondo that I do not have to mix to use.
cudaken
I am back
Baldwinvette77
They all gotta be mixed with an activator :yesnod: Anything that air drys wouldn't be as durable
71green go
There are/were UV activated fillers that are not air dry.....they are gummy when sanding, I have used them on junk cars in the past as it was given to me free....Don't bother its JUNK......use a good brand filler....Bondo brand to me is not the best out there, use some from evercoat
bill440rt
Rage Gold is my preferred filler.
:Twocents:
There are fillers that auto mix from the tube like Evercoat Quantum 1.
Indygenerallee
tsmithae
Finoke
Buy a better filler and you won't mind mixing. I was amazed after using the new stuff like Rage after not using filler for 20 years. So much easier to apply, spread and sand. No pinholes or gum  :2thumbs:
sanders7981
Quote from: tsmithae on April 12, 2014, 10:24:33 PM
Rage Gold here.  :2thumbs:
Rage Gold and Extreme are what I used on my charger... Although they have not sit up for more than 2-3 years after being applied, I can confidently say there was absolutely no shrinkage on any of the areas!!  Ovce I did filler, I didn't get to paint until a year ago.  Product is very easy to work with and sand.  Even though I am by no means a professional body man, I highly recommend them as they were easy to use and have held up great!
Whatever you get check "out date" first before buying!  :2thumbs:
Silver R/T
Anything by Evercoat or USC is great stuff, forget Bondo brands, just cheap crap for car lots.
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
elitecustombody
There is, you just have to spend some money. Special gun does the mixing for you. All you do is pull the trigger and spread. Otherwise I'll advise to stick with Evercoat line. Extreme and Gold are very good fillers. :Twocents:
Stefan
Quantum 1 in the self mix cartridge that's the size and shape of regular caulk guns has been discontinued.
