383 stock engine help
Started by bobfist, March 20, 2014, 04:15:24 PM
bobfist
Hi!
I have my factory stock 440 magnum in my charger 69 rt
but now im going to restore my RR 71 and need some help with information
I just got my hands on a stock 69 RR 383 engine the closest i came to my 71 , anyway it came from a RR :)
But now i need to know how this engine was built compare to the 69
I know the heads where diff, intake manifold and , ex manifolds pistongs 8:5:1 anything else inside ?
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
cudaken
Quote from: bobfist on March 20, 2014, 04:15:24 PM
Hi!
I know the heads where diff, intake manifold and , ex manifolds pistons 8:5:1 anything else inside ?
Far as rotating mass you are good to go. They are both forged cranks, internal balanced motors and pretty sure the same rods where used, I think YL casting :scratchchin:
Funny, you have a 69 Road Runner engine for your 71 Road Runner, and I have a 71 Road Runner engine in my 68 Road Runner. 68 and 69 Road Runner engines where the same. But, I also still have my original Road Runner engine.  :2thumbs:
Cuda Ken
I am back
bobfist
Thanks for answer
but does anyone know if the 71 383 rr used the 346 heads or the 906
I have diff info on that.
also are the porting the only diff on these heads?
www.bobfist.com
Sweden
heyoldguy
For 1971 there was a change during the model year. Early 1971 big blocks came with 906 heads and later in the year they switched to 346.
bobfist
ok, but was it only the porting that was the diff?
I have B11 build date at the fendertag, so i guess this car would have 346 heads, date 11/11/71
www.bobfist.com
Sweden
11/11/71 would be a '72 model year car. 11/11/70 would be a '71 model year car.
bobfist
but that is what my fender tag says B11, and its a 71 model i have
www.bobfist.com
Sweden
heyoldguy
Quote from: bobfist on March 21, 2014, 12:36:53 PM
The difference was the shape of the ports. The heads will interchange on the 440 and all parts will interchange between the two heads.
71 SE3834V
Quote from: bobfist on March 21, 2014, 03:39:33 PM
Don't if this info is the same but might help. I have a '71 Charger. Fender tag has B11 which translates to a build of Nov. 11 from what I found out. Door sticker shows build date of 11/70.
71 Charger SE 383 4V
72 Galaxie 500 400 2V
yes...B11 is build date of Nov. 11, 1970....early car
bobfist
Ah so b11 is 70? Nice!
Bec if i run my VIN: RM23 N1G 143864 in decoder it says 71
vin decoder says 143864 = 43863th Vehicle, is that early ? :)
Then it could have the 906 heads then, if some was leftovers.
www.bobfist.com
Sweden
RECHRGD
Pull a valve cover and check the numbers stamped on the head....
13.53 @ 105.32
346/906 will not matter for your build they look identical. While in stock condition I read that 346 will slightly outflow 906's on exhaust the real difference was that 346 were induction hardened exhaust seats for unleaded fuel. Induction hardening is just a surface hardening, a couple of valve seating's and it's removed anyway.   A 69 838 would be 906 heads if original.
71 SE3834V
Quote from: RECHRGD on March 23, 2014, 09:27:43 AM
Where should one look for the #'s? And are you looking for stamped #'s not cast #'s?
Reason I ask is I had my DS cover off last year and only found a 7 digit # casted in the head and a 4 digit # that seemed to be stamped on a plate and attached to the head. Might help the OP.
Quote from: bobfist on March 23, 2014, 06:17:34 AM
Car model year is 1971 built in Nov. of 1970.
Cooter
Quote from: 71 SE3834V on March 23, 2014, 11:26:46 AM
Look along the intake runner. There should be a series of numbers like, "3462906", or "55453346"
won't be exactly like these, but you get the point.
71 SE3834V
Quote from: Cooter on March 23, 2014, 11:41:04 AM
I modified my above post but will add more info since you were so fast to reply Cooter.
The casted # I found was 3482348. Sound right?
RECHRGD
The last number is most likely a 6 not an 8......
13.53 @ 105.32
Cooter
Yeah, looks to be "346" heads.
71 SE3834V
This is the only pic I took. I'm planning on pulling the pass side this year to check the movement of the rockers/cam condition. I'll look for the number on that side and clean it a bit.
So by Nov. 1970 it looks like they were building w/the 346 heads.
