1968 VIN confusion
Started by schuperboyd, March 12, 2014, 08:42:58 PM
schuperboyd
Looked at a '68 Charger today but the dash vin tag doesn't match the radiator support or trunk stamp. Any idea as to what the first letter in this stamp is AND what is the significance of the "X" in the assembly plant spot? Thanks.
69CoronetRT
A 68 does not have the VIN on the body.
What you are seeing is:
B= plant code=Hamtramck
8=year
X= first letter of the VIN and body type designation = Charger
remainder is the Sales Order (SO) number which should match the number on the bottom row of the fender tag.
You can't match a VIN to the SO in 68 without the broadcast sheet, window sticker, IBM card or some other document that has both numbers on it.
schuperboyd
Ok I got you. Thanks a lot!
bakerhillpins
Here are some links that show how to check the numbers on Mopars. Its a tad thick since its different for 68s and 69s. Start with the first and be aware that the 2nd is primarily about 68s and the 3rd about 70s.
http://andy440.com/other.htm
http://www.dodgecharger.com/forum/index.php/topic,38316.0/all.html
http://www.hamtramck-historical.com/numbersMatching.shtml
http://www.dodgecharger.com/forum/index.php/topic,32660.25.html
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
TexasGeneral
69CoronetRT
Quote from: TexasGeneral on March 13, 2014, 12:38:51 AM
A little off topic but I'd say that one was built early model year of '67
You can't determine SPD by the SO number
mightywing7
Quote from: 69CoronetRT on March 13, 2014, 06:50:44 AM
Wow!  May 16, 1968 with such a low sequence number.  Very interesting.
Thanks for sharing!  :2thumbs:
1968 Dodge Charger R/T - 440 Magnum, 727
1968 Dodge Charger - 318, 904
1985 Chrysler LeBaron Turbo Convertible, Mark Cross - 2.2L Turbo
1987 Buick Grand National - 3.8L SFI Turbo
2006 Chrysler Crossfire SRT-6 Coupe, Supercharged 3.2L
2006 Chrysler 300C SRT-8, 6.1L HEMI
69CoronetRT
Quote from: mightywing7 on March 13, 2014, 08:04:41 AM
Yes. Due to the way SO numbers were generated/assigned the actual number has nothing to do with SPD. Theoretically, the lowest SO numbers could be on the cars produced last.
