91 w150 318 cam help
Started by 91w150, February 05, 2014, 03:48:32 PM
91w150
I have a 1991 dodge w150 and I want to put a new mild cam in it, but I realize with the throttle body injection it has that I can't just go strapping one in. I already had plans of putting a new edelbrock performer series 500 cfm in it and a new air intake. I was told if I was going to keep it tbi then I needed to find someone that could burn a chip for it and was wondering if anybody knew how I could find someone that could do that and if I needed anything to get ready for a cam. Just got painted and want more power and sound to show it off. Thanks!
chargerbr549
On the cam swap, one option is to have your cam reground to a different profile and reuse the hydraulic roller lifters and maybe go with longer pushrods? I don't know for sure what options are available on modifying your tbi set up but you can swap to a performer manifold and carb and ditch the tbi setup. I had a tbi 318 out of an 88 ramcharger that I used a factory 360 thermoquad and performer manifold on it in my 82 Mirada and it ran very well, it was the best running 318 that I ever had.
Cooter
That TBI set up is a speed density (map sensor) and relies on engine vacuum to meter fuel. Too big a cam and it will not run without loading up.
