Vin last 7 digits
Started by Sixtyeight, January 26, 2014, 11:03:55 AM
Sixtyeight
Hi,
Is there a way to decode a VIN from the last 7 digits?
It's G119126 and stamped on a F 440
Would be great!
Jeroen
Charger Registration of the Netherlands / www.charger.nl
1968 R/T Charger
1969 Base Charger
rarefish
Are you talking about a VIN stamped on a engine block?
The last 6 are a serial number.  Everything before it is where you'll find the info you seek
Sixtyeight
Hi,
see attached file
1968 R/T Charger
1969 Base Charger
Sixtyeight
Quote from: stroker400 wedge on January 26, 2014, 11:07:54 AM
I know but wit recent cars is its also the case and if you take the last 6 in the system you find the whole info. I know this because i work in a dealership.
Jeroen
1968 R/T Charger
1969 Base Charger
rarefish
The last 6 numbers are just production sequence numbers. Not like today's VIN's  where there is a lot more info..
Well, the 'G' is the assembly plant (St Louis in this case) so you could at least narrow it down to the cars that were being produced there. Is that a '0' in front of the 'G'? The stamp should have the year as the first character.
Sixtyeight
Yes,
That's a zero, good call!
Jeroen
1968 R/T Charger
1969 Base Charger
Alaskan_TA
F is the series (model year) 1970 in this case.
The VIN is missing one digit, there should be a zero since it is an F series block - 0G 119126
G is the assembly plant for the car, St. Louis, Mo. & only B-bodies were produced there for 1970, including all of the 1970 Chargers.
69charger2002
Modern cars keep lots of VIN info based on the last 6 of the VIN. Dealerships(s you probably know) ask for it when referencing parts etc. Not so on older ones. Like said before, from the info you have ,all that can be surmised is it's a 70 block, built at ST louis, with a reasonably early 70 model VIN, probably somewhere in the late august or early september range of 1969 as a build date. Being a 440, it can at least be narrowed down to a Charger R/T, Roadrunner, GTX, or Coronet R/T.
Sixtyeight
Well, that's great info, and all I need to know, thanks!
Jeroen.
1968 R/T Charger
1969 Base Charger
