Spare size
Started by Ghoste, January 19, 2014, 08:35:07 PM
You people with different size tires front and rear, what do you carry for a spare as far as size?
Original F70-14 and a AAA card!  ;)
Have an original and a credit card which is nearly the same but I think I'd like to have a useable one for long hauls. :scratchchin:
if your car is a sure-grip...get a spare to match the rear size in total diameter...width makes no difference
It is and that makes perfect sense, thanks.  I was beginning to lean to the idea of one halfway between the two sizes but I understand why you would want the rear size with a limited slip.  Never even considered that Bryan.
stripedelete
What if you don't have a sure grip?    Match the front?
that depends on you...if size is an issue..and you have a real tall tire in back..the same height tire may not turn on the front...depends on the size difference I guess....
I'm in that boat.  I have the stock spare in the trunk, a relatively same height wheel up front but a way taller tire in the back.  Either the tire place will be close by so I can limp there or it'll be flatbed time when a rear tire goes.
If it's an open diff, would my idea of something halfway between the two diameters work?
471_Magnum
Jeep 155 90 16 on Town Car 16 X 4.5 aluminum wheel with the center register hogged out a couple thou.
27 inches with about 3/4 inch offset, if memory serves.
Big write up over on Moparts. Pretty sure I've post something here as well. I'll dig up a link later.
Quote from: Ghoste on January 20, 2014, 09:16:47 AM
yes
471_Magnum
1974dodgecharger
Still trying to find a suitable spare for my car.  Trying to match up fronts I figure if rears goes out the same size front should be able to drive her but damn putting a 30inch tire in trunk I never tried.
Do you have a Sure Grip?
1974dodgecharger
Again, if you do not have a sure-grip, you can run any size tire for a spare you want.
If you had a sure-grip rear end, you should run the same size tire in height as the rear tires as not to tear up the clutches in the carrier if you have a flat on the back
1974dodgecharger
Excellent I should put that sure grip in...damn.
charger Downunder
Original tyre from 1970
[/quote]
polywideblock
so does anyone use "goop " or "slime "  or a similar preventative ?
  and 71 GA4  383 magnum  SE
I would only use it if it was absolutely necessary, otherwise, no
1974dodgecharger
Quote from: polywideblock on January 30, 2014, 01:30:00 AM
Does that stuff even work?
Quote from: 1974dodgecharger on January 30, 2014, 02:44:03 AM
It works for small nail and screw holes.  It's not really meant to "fix" the tire, but just seal it up enough so you can get it properly fixed at a tire store.  Tire places hate it.
polywideblock
they sell the goop over here for 4WD and its in there all the time just seals them as they come
                                 http://www.ebay.com.au/itm/Goop-Tyre-Puncture-Sealant-Puncture-Preventer-Proofer-Kit-500ml-Bottle-UK-Made-/181301289031?_trksid=p2054897.l4275
                                   click full description
1974dodgecharger
I've used Goop in a minivan and thats about it.  I don't think I'd use it in the Charger unless it was my last resort.
