best front disc brake kit
Started by Al, December 31, 2013, 08:31:03 AM
Al
Quote from: el dub on January 11, 2014, 02:33:25 PM
Sorry, my fault. I wasn't reading correctly, I've got power disc brakes.
no problem  :cheers:
1968 Dodge Charger, 383, UU1
Al
Quote from: bill440rt on January 11, 2014, 03:04:06 PM
I should have been more specific as well.
The car is a manual brake car, I kept manual brakes due to the low vacuum producing cam that's in it. I also did not want to install a hydroboost, as the engine compartment is very stock appearing.
The manual disc brakes perform MUCH better than the manual drum brakes. The six-piston Wilwoods I have on my '69 with the hydroboost perform MUCH better than the manual discs, which is no surprise.
In short, yes it's an improvement. I don't mind the manual disc brakes. The car stops easily to me. I see no reason to put in a booster.
If you feel you need one, you can always install a booster. MP sells them separately.
Thanks for this clear reply.
By the way, did you keep your original master cylinder when you installed the disc brakes?
Al
bill440rt
No, Al. You must swap the drum/drum MC for a disc/drum MC, which is supplied in the kit.
I found the thread where I did the swap, it starts on pg 2 about halfway down.  :cheers:
http://www.dodgecharger.com/forum/index.php/topic,84534.25.html
Al
Quote from: bill440rt on January 12, 2014, 10:05:24 AM
Thanks for sharing  :2thumbs:
six-tee-nine
What about the Dr. diff kits?
Anybody tried these yet or knows someone who has them.
Mr. Lee
Quote from: Mopar Nut on January 11, 2014, 03:41:21 AM
Quote from: Mr. Lee on January 10, 2014, 03:42:40 PM
If I can hop in on this topic, wich disc brake kitt will work for the 14x7 Vector wheels?
Thanks  :2thumbs:
I have Baer disc up front with 14" wheels now, i'll look to see the model.
Did you perhaps look at the model already?
Quote from: six-tee-nine on January 13, 2014, 07:07:48 AM
I have Dr Diff kits on the front and rear but the car isn't on the road. They are also original factory equipment - they just happen to be for Fords (2000+ Mustang Cobra front and Explorer rear).
Skull-1
Thanks  :2thumbs:
I would love to know.  I don't want to give up my stock hubcaps.
http://www.dodgecharger.com/forum/index.php/topic,6231.0.html
1969 Dodge Charger "Ol' Yeller"
1991 Buick Regal Custom
1992 Buick Regal Custom
1995 Buick Regal Gran Sport
1996 Buick Regal SE (R.I.P.)
Mopar Nut
Quote from: Mr. Lee on January 13, 2014, 10:29:43 AM
Thanks  :2thumbs:
Yes, they're Baer BAE-4141046
Skull-1
http://www.summitracing.com/parts/BAE-4141046/
So now the question is....   Can I use my existing booster and master cylinder with a proportioning valve along with this kit?
Disk brakes require a larger volume of fluid than drums do. You must have the correct master.
Skull-1
Quote from: b5blue on January 13, 2014, 05:22:19 PM
Hmmmm.....   I don't suppose the right one is intuitively obvious then?   Any suggestions for use with the 14" kit above?
That kit is N/A...not available.  :rotz:
Skull-1
Quote from: b5blue on January 13, 2014, 08:17:12 PM
Failed to note that in my excitement.    :brickwall:
Mopar Nut
Quote from: Skull-1 on January 13, 2014, 09:51:21 PM
I checked with Baer today on that, the reason is the brake calipers is not available new. You still can buy the brackets, SS brakes lines and rotors through Baer and brake calipers through a local parts place.
Al
By the way, are MP Brakes still in business or are they closed?
I've been send them mails for 2 weeks but I get no reply.
Al
Skull-1
Quote from: Mopar Nut on January 13, 2014, 11:17:41 PM
Exxxxxxxxxxxxcellent.   Thanks.   :2thumbs:
Skull-1
Al
Just for information:
MP brakes is either out of business or doesn't care to reply to mails send them from overseas.
If they don't even care to reply to potentiel customers, I wonder what would be their technical support if you buy their disc brake kits in a country outside the US.
Considering that such a kit is not cheap and costs quite some $, I find this attitude despicable.  :nono:
Mopar Nut
Quote from: Al on January 24, 2014, 01:35:08 AM
:iagree:
chargerboy69
I have the front power disc brake kit from Cass (Dr. Diff).  It is absolutely fantastic. Booster, master cylinder, lines, spindles, drilled and slotted rotors, Cobra calipers and all hardware for $1050.00 shipped to my door.  A non power set up is about $650.00.
Fantastic customer service.  Many times I e-mailed him, I had a response within five minutes or pick up the phone and give him a call. I highly recommend his kits.
http://www.doctordiff.com/
Indiana Army National Guard 1st Battalion, 293rd Infantry. Nightfighters. Fort Wayne Indiana.
A government big enough to give you everything you need, is a government big enough to take away everything that you have.
--Gerald Ford
twodko
Bad news about MP brakes. They were always very good across the board......sad to hear.
Al
Quote from: chargerboy69 on January 24, 2014, 10:01:37 AM
Thx for the link. I've sent him a mail.
Skull-1
Is anyone doing them for 14" wheels?   I don't want to ditch my stock setup.  :(
