3 bolts
Started by el dub, December 30, 2013, 06:57:55 PM
el dub
Are the 3 bolts that hold on the steering wheel for a 66, 67 charger the same as the 3 bolts for a 68 charger. I bought a superior steering wheel a long time ago and am trying to get a horn kit for it. There is one for a 66, 67 on ebay and I'm wondering if it will work for a 68. Thanks
What three do you mean, there is only a nut holding the steering wheel to the splined shaft?
el dub
When you put an aftermarket steering wheel on you get a kit with an adapter for the copper horn ring that has 3 holes in it you bolt the new steering wheel to. You also use the single nut. I'm just looking for the horn kit. Google Superior "500" Steering Wheel Horn Kit ,#86-1700,Chrysler,Dodge,Plymouth. Its for a 66, 67 and I'm wondering if it will work on a 68.
Oh okay, now I get understand.
ODZKing
Here is a pic of a steering column from a 66 if it helps
