340 stroker kit
Started by randy73, December 26, 2013, 06:13:31 PM
randy73
Engine is tired and needs rebuilding, so I am looking to stroke the engine to a 373 or there abouts and was wondering what kits are out there and what companies make quality kits?
BTW: I am also going full roller rocker and I just installed a 46rh tranny w/2300 stall converter.
cdr
There are a bunch of places to buy small block stroker kits. Cheap too! Ohio Crank and RPM come to mind. I have heard that 340s generally shifted a good amount and finding a block suitable for stroking can be difficult. I haven't checked either of my 340s to see if this is the case.
69wannabe
You can stroke the 340 up to a 416 cubic inch at 30 over. Built one a few years back that was an awesome running small block!!! Just get the better H-Beam rods and not the I-beam rods. Have seen several engines fail from these cheaper rods being used. We ran the engine I built for a couple of years at the drag strip hard and spraying it with a 175 shot before it blew apart. If it wasn't for them I-Beam rods that engine would still be running. It was an impressive small block tho, we had it in a 68 barracuda fastback and outran all the cars we ran it up against that was basically similar in HP/class. Got a best of a 6.65 in an 1/8th of a mile with it. My 440 wouldn't touch it but it wasn't built for the drag strip tho, it was built for the street instead.
