Out put shaft seal
Started by fy469rtse, October 08, 2013, 04:45:13 AM
fy469rtse
Can anyone give me the correct part numbers of the different manufacturers for the correct rear extension housing seal, the one the one that shields a portion of the slip yoke shaft, ?
Had two go's at purchasing them from rock auto, looked up using there menu, selected correct transmission for 440 727, showed they had 5 in stock , and a photo as an example , couple of friends wanted them as well, bought the 5 wtf what showed up was for 904 transmissions, no reply from them , once they finally replied promised they would send out the correct part, yep sent out the generic seal with no lip and charged me for the privilege of replacing the seals with the wrongs ones again , so my friends didn't need the wrong ones so guess how's left with them. So part numbers and best place to get them , not rock auto, lack of customer service will result in you having no customers to treat badly .
fy469rtse
Thanks John looked at my receipt to see if there was a part number on there, but no , won't be buying it from rock auto, but thanks for the correct seal part number , and thanks for the reply
