440 in 383 charger
Started by 69dodge383, August 19, 2013, 03:27:22 PM
69dodge383
putting a 440 in a 69 charger 383. 440 is in. frame mounts are one inch below motor mounts. Its not lining up or wanting to settle in.
I have put motors in before and they would just drop in. I replaced the orig 383 with another 383 and never had this kind of trouble.
I think I have an issue with the the mounts.
Any ideas?
The way I bought it
1969 Dodge Charger SE
383 Magnum
727
3.23 open 8 3/4 - 489
PS/MB
The way it is
1969 Dodge Charger "The Duke"
440HP '72
10.5:1 Mopar Pistons @.030 (446 c.i.)
Edelbrock Performer Heads
Hughes Solid Lifter Cam 278/283 245/250 .597. 613 108
7Qt Oil Pan
Victor Intake
Demon 850 Carb
TTI Headers 2" Primaries
727 Manual Valve Body
9" Dynamic Converter
4.10 Sure Grip 8 3/4 - 489
3" Dual Super 44
Coys 18x9 20x10.5  Cragar 15x8 15x10
All big blocks from '66-'72 used the same mounts/brackets, if it doesn't fit suspect the accuracy of the mounts...are they new?
69dodge383
Mounts are new. I have the mounts from the 383 that I pulled and they are in good shape. Should I try those?
The way I bought it
383 Magnum
727
PS/MB
The way it is
440HP '72
7Qt Oil Pan
Victor Intake
Demon 850 Carb
3" Dual Super 44
Sure, try the old ones from the 383 to confirm that the new mounts are the problem.
69wannabe
It should drop rite in there with no mount issues. I put a 72 model 440 in my charger where a 69 383 came out. Bolted in with no problems except had to work the headers over with a hammer to keep them from hitting on the steering box and torsion bar.
Bossman963
I dropped a 440 in my 68 Charger with no problems @ all everything mounted up perfectly- are you sure that car came with a BB originally  :shruggy:
68 Charger 440- under construction
70 Challenger R/T 383 in 2nd version of Vanishing Point. 4 SALE
69 Boss 302
70 Boss 302
74 pantera GTS
Cooter
Mounts all but have to be the problem as all bb Chryslers have exactly the same block mounting ears from mounts down. Only diff. I'd the deck height.
Bossman963
sorry for stealing the thread- but Cooter ever get that grille done ???
69 Boss 302
70 Boss 302
74 pantera GTS
69dodge383
I got it in. There was two holes on the driver side mount. I moved the bolt to the other hole and it dropped right in.
The way I bought it
383 Magnum
727
PS/MB
The way it is
440HP '72
7Qt Oil Pan
Victor Intake
Demon 850 Carb
3" Dual Super 44
Cooter
Quote from: Bossman963 on August 26, 2013, 10:22:42 AM
yessir..looks really good and thanks again bossman...what'd you do with that 69grille?? I'm sure some here would love it.
Can't wait to see your grille Cooter :popcrn:
Bossman963
Cooter glad U got it done & in
the 69 grille is still sitting in the box and havent done anything with it yet !!!!
maybe I should find a 69 to put it in ??? :shruggy: :shruggy: :2thumbs: :coolgleamA:
69 Boss 302
70 Boss 302
74 pantera GTS
