440 Torque specs
Started by 2Luke2, August 06, 2013, 08:03:01 PM
2Luke2
So since we are putting an engine together I had to look around for torque specs for pretty much everything. So I thought I would post a list here and let you guys rip it apart if you see something that doesn't seem right. These numbers don't take into account using ARP hardware. Let me know what you think.
Was trying to make a nice list of torque specs and wanted to know if this list looked good. Obviously I need to use the ARP specs if I'm using arp hardware.
A/C Compressor to Engine Bolt 30ft lbs 3/8-16
Alternator Adjusting Strap Bolt 200 in lbs 5/16-18
Alternator Adjusting Strap to Block Bolt 30ft lbs 3/8-16
Alternator Mounting Bolt 30ft lbs 3/8-16
Camshaft Lockbolt 35ft lbs 7/16-14
Carburetor to Manifold Nut 7ft lbs 5/16-24
Clutch Housing Bolt 50ft lbs 7/16-14
Connecting Rod Nut - Plain 45ft lbs 3/8-24
Crankshaft Rear Seal Retainer 30ft lbs 3/8-16
Crankshaft Bolt (Vibration Damper) 135ft lbs 3/4-16
Cylinder Head Bolt 70ft lbs 7/16-14
Distributor Clamp Bolt 15ft lbs 5/16-18
Exhaust Manifold Nut 30ft lbs 3/8-16
Exhaust Pipe Flange Nut 50ft lbs 7/16-20
Exhaust Pipe Clamp Nut 20ft lbs 3/8-24
Fan Attaching Bolt 15-18ft lbs 5/16-18
Flywheel Cover Bolt 7 ft lbs 1/4-20
Flywheel Housing to Block Bolt 50ft lbs 7/16-14
Flywheel to Crankshaft Bolt 55ft lbs 7/17-20
Fuel Pump to Block 30ft lbs 3/8-16
Intake Manifold Bolt 40ft lbs 3/8-16
Main Bearing Cap Bolt 85ft lbs 1/2-13
Oil Pan Drain Plug 20ft lbs 1/2-20
Oil Pan Bolt 15ft lbs 5/16-20
Oil Pump Cover Bolt 10ft lbs 5/16-18
Oil Pump to Block Bolt 35ft lbs 3/8-16
Rocker Shaft Bolt 25ft lbs 3/8-16
Spark Plug 30ft lbs 14mm
Starter Mounting Bolt 50ft lbs 7-16-14
Timing Cover Bolt 15ft lbs 5/16-18
Torque Converter Housing Bolt 30ft lbs 3/8-16
Torque Converter to Flexplate Bolt 270in lbs 5/16-24
Valley Pan End Bolt 9ft lbs 1/4-20
Valve Cover Stud & Nut 7ft lbs 1/4-20
Vibration Damper Pulley Bolt 200in lbs 5/16-20
Water Pump to Housing Bolt 30ft lbs 3/8-16
Water Pump Housing to Block Bolt 30ft lbs 3/8-16
ottawamerc
Great post :2thumbs: I too searched before when I was building my engine and this list would have been very helpful.
Scott :cheers:
This hobby is more than just our cars, it's the people you get to meet along the way!!!
71green go
With the exception of the head bolts, the main bearing bolts, the rod nuts and the flywheel bolts, how many here actually use a torque wrench on anything else?
2Luke2
Quote from: John_Kunkel on August 08, 2013, 02:24:27 PM
Me lol.... most likely because I'd rather be safe than sorry. :)
Fred
Exactly, there are exceptions but for the most part my arm is my torque wrench. I do it mostly by feel.
