hemi style fuel pump
Started by charger01, July 24, 2013, 10:33:23 PM
charger01
my 69 440 hp has a hemi style fuel pump with vapor seperator.  I am unaware of the fuel pressure output on it, but is this pump not meant for my application?  its pretty much a stock build with eddy 750 carb.
Fred
Pump is fine, you're good to go.
Ive run the Carter pump for many years with no issues
Same here and on smaller demand engines than a 440 too.  I have one on my 383 right now with a pressure regulator but it admittedly needs a little more than stock on it.
Dodge Don
I use the Carter High Volume Hemi fuel pump to feed my six pack. Only issue was at Carlisle this year where the diaphram got a hole in it and it was spitting fuel out of the top. I got another at the Mancini booth and had the car back in operation.
