Seat belt holes
Started by Grm2159, June 08, 2013, 09:37:42 PM
Grm2159
So I pulled the carpet out of my 69 charger. Threaded holes for seatbelts are in the center hump and that's it. Rear seat belts are fine. Anyone have pics of where holes should be on the outer side?
They aren't in the side of the sills?
70 sublime
This is the best picture I have on the computer
My 69 Charger
You can see the 2 bolts for the driver seat
Grm2159
I wonder why?  It seems like more trouble than its worth.
green69rt
Can you see any evidence of where they are??  Maybe you can dig out the filler (hope they didn't weld them up.)   Then run a tap down thru them.  There is a nut welded to the inside of the inner rocker that provides the threads so you can't just drill a hole anywhere.   I guess as a last resort you could weld a nut to the floor  :shruggy:
Grm2159
Looks like a lot of seam sealer in that area. Will have to get a good idea of location before I start digging
Be nice if they are just filled with sealer and not welded over.
