Repair or replace
Started by mAdMoPaR, August 21, 2009, 12:33:05 AM
That's why I'm going with SS pure white, is it what I want (B5 Blue) no, is it good enough for now, sure.  :scratchchin:
fy469rtse
Quote from: mAdMoPaR on August 21, 2009, 12:33:05 AM
Hello all, Long time reader first time post. Need a little advice on fixin the rear window channel on my 68 charger (see pics) Should I replace with new sheet metal? or does it look like i might be repairable? Gonna have the trunk floor replaced so I figured it might be easier to replace the deck panel at least with the trunk floor removed. Not sure how easy the sail panels are to replace though, not really a bodywork type.
now is the time to do it properly, otherwise it will come back to haunt you later , cut it , get the new panels , I think charger specialtys have a good fit sail panels replace the deck or Dutchman panel you might also need lower window frame, you will know once you get Dutchman panel cut out, it will give you a chance to clean up plenum under that, even if you can't do body work, I'm sure someone has posted photos on here as a guide, at least if you remove all this and know you need , less work and cost for who ever does the work for you
mAdMoPaR
Window corners done!  :2thumbs:
mAdMoPaR
Finished truck lock support along with spare tire and jack braces/brackets.
mAdMoPaR
Will be skim coating welds with duraglas before primer. Should seam sealer come before or after primer? Was thinking of using Evercoat brushable seam sealer.
Fred
lexxman
