PST Torsion Bars
Started by Ryan.C, May 16, 2013, 08:46:18 AM
Ryan.C
Just installed a set of PST Torsion Bars.
The problem I am having is these bars are not clocked properly. I have to run the adjuster way up to get the bar to slide into place. will this cause a problem when i get the car off the jack stands and set ride height? Has anyone installed a set of PST bars?
any advise is appreciated
There are few problems in life that cannot be solved with C-4.
WHITE AND RED 69
When did you buy the bars? Apparently there were some bad batches made a while back. If that is the case call up PST and they will help you get it right. The newer bars are clocked right.   :cheers:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Ryan.C
Ryan.C
FYI PST confirmed the wrong bars were sent.
