Trim removal
Started by Evolution69, May 18, 2013, 02:13:36 PM
Evolution69
Hi guys, Removing trim, done the drip moldings but not sure of the piece that goes across the door and the one on the quarter panel, plus the one on the rear window, and tips advise would be grateful  thank you and enjoy your weekend.
Matching numbers 1968 Dodge Charger RT
"Because bad guys always drove Chargers" - Richard Hammond
 have a look at Bill440RT & Shakeys awesome threads  , shows all the stuff you looking for
http://www.dodgecharger.com/forum/index.php/topic,23879.0.html
http://www.dodgecharger.com/forum/index.php/topic,43619.0.html
http://www.dodgecharger.com/forum/index.php?PHPSESSID=837hmsnrf38k7n75frk263uon3&/topic,30095.0.html
http://www.dodgecharger.com/forum/index.php?PHPSESSID=5nsho4pq3ug35pe9ik1sojp193&/topic,1189.0.html
there are loads of posts on what your asking & lots of stuff to read & pictures  , Do a Search , everything is here,  :yesnod:
rear glass needs to be cut out , using piano wire or or a propper air powered knife , its the same as what the hospital uses to cut a plaster cast off except with a long blade attachment  :o :yesnod:
first  picture below , of the stainless trim clip unhooking tool , they are not a picture of a charger , but its the same .
 other three are a choice  are a choice of  stuck / bonded  / butal taped  in  , glass  removel tools
Mopar Nut
Quote from: Evolution69 on May 18, 2013, 02:13:36 PM
Use a putty knife and lift it up, comes right off.
Quote from: Mopar Nut on May 19, 2013, 06:10:09 PM
:yesnod:  yep MN got it   :2thumbs:
, use a wide one ,  if your paint is good slide a bondo spreader under first to protect paint  , also need to undo this nut first , same with the long quarter panel vinyl top stainless , the long ones on the out side have two speed nuts at , that are accessed from inside the trunk , then same deal as what MN said on top of door , also when your doing this ,  slide the putty knife or similar right up to /almost touching the clip before you pry it up , if you pry in the middle between the clips , can/could bend the trim , the two smaller pot metal / cast chrome plated vinyl top trim , are held on by three speed nuts each side , accessed from  inside the trunk   :yesnod:
Evolution69
