Front end
Started by flathead1946, May 14, 2013, 07:43:27 AM
flathead1946
I am rebuilding the front brakes on a 1968 charger (Drum). When I removed the backing plate the upper and lower control arms seperated. i have no engine in the car. I've placed a jack under the lower arm in an attempt to close them but it just raises the car. Any tricks to putting it back together? Thanks in advance
green69rt
I don't understand your situation.  taking the backing plate off should not allow the arms to separate.   They are still attached to the spindle.   A jack under the lower CA will lift the car unless you back off the torsion bar adjusting bolt, especially with the engine out.  Here's a pic of a my car sowing the two CA's and the spindle. no backing plate.
charger Downunder
You may have to unwind the lower torsion bar height adjusting bolt on the side you are working on.
[/quote]
Hard Charger
back off the torsion bar adjuster.
flathead1946
Here is a picture of what I am talking about. I need to close the distance between the lower control arm and the bottom two bolt holes on the spindle. see fingers. thanks again
hemi68charger
Quote from: flathead1946 on May 16, 2013, 10:04:16 AM
Grab the end of the ball joint and pivot it so the far hole lines up and slide a bolt in. Then, you will be able to push/pull the ball joint the other direction to align the other hole up... Works every time for me...
Houston Mopar Club Connection
charger Downunder
Place another jack under the lower control arm and jack it up, grab the top ball joint and pull the upper control arm fully down and pivot it around. If still cant get it in pull the torsion bar or back off the adjuster.
[/quote]
green69rt
Again, have you backed the torsion bar adjusting bolt out to take the tension off?  Once that's done the LCA should move right up so you can make the connection.
