Nascar question
Started by flyinlow, April 29, 2013, 12:42:03 PM
flyinlow
Do Nascars have limited slip axles?
Aero426
odcics2
Green71R/T
Quote from: odcics2 on April 29, 2013, 08:13:27 PM
:iagree:
Detroit Locker.
Not a Spool? we ran fully locked on an oval.use stagger and alignment to corner.actually had  to work to go straight.let go of the wheel and it goes left on its own.
Highbanked Hauler
 Is a spool and a ratchet the same thing ? :shruggy:
92 Cummins Turbo Diesel
04 PT Cruiser
Cooter
Quote from: Highbanked Hauler on April 30, 2013, 09:36:12 PM
No....
Spool is a machined piece of steel, with splines in both sides and NO seperate pieces at all, that Actually "locks" both axles together all the time. No "Ratcheting" at all. Good way to break sh*t on the street. (Friend found this out the hard way with mustangs.
Any "Ratcheting" unit will give and therefore, is called a "differential" for that reason.
Indygenerallee
On all the street stock classes most of the guys at my track just weld the spider gears, works and it's cheap, You just have to make sure you clean the tar out of it with about 5 cans of brake parts cleaner!
