Speedo gear?
Started by mikeydf14, April 25, 2013, 06:24:14 PM
mikeydf14
Finally got the Charger out for a check run after being in the resto shop for a year.  We put her into the wind and it drove great. However, it seems the speedo is way off due to the incorrect gear in the trans. The GPS said we were going 53 when the speedo showed 70 and then the GPS showed 65 and the speedo showed 80.  Obviously I need more teeth for that gear. I do not know what gear is in the car but I found a Mopar sight giving me a good idea what I need. Their calculations indicate I need at least a 32 tooth gear.  Other than Year One does any one have a reputable and reasonable supplier(s) I can use?  Thanks Mike!
fy469rtse
Quote from: mikeydf14 on April 25, 2013, 06:24:14 PM
most ransmission shops and suppliers have these gears SMR or patc , look im up , thats where i got mine , just check the size gear teeth number first ,
Before you change the pinion check the odometer over a known distance. The odometer is direct-driven and will be a better way to judge the error.
E-bay always has a wide variety of pinions for sale.
mikeydf14
OK Thanks for the odometer idea! Just checked Ebay and sent a question to a vendor about one of their pinion gears.....
Fred
Have you tried A&A Transmissions?
I just went to our local tranny shops around here and got some...paid like $5 each when they charged me for one...
Bryan
randy73
PATC in La is where I got mine.
red79
cope racing transmissions fixed me right up  :2thumbs:
