air conditioning
Started by cowboy4x4n, April 18, 2013, 10:12:44 PM
cowboy4x4n
will a complete ac system from a 1970 plymouth volaire fit into my 69 charger
cowboy4x4n
I've never done it, but I'd say  the major components would work.  I say you'd probably have to get the hoses made.
Cooter
Depends on whether you have a BB and looking at a SB set up. The SB to BB and Vice Versa, won't work without ALOT of fab work.
Not aware of ANY Volare Set ups that were BB factory, so....
Underdash Evaporator will be different for different heater boxes.
I'd say your better off finding a Charger/B-body specific unit/set up.
Yeah I don't think that would work, it won't be a direct bolt in I can tell you that.  Unless you can find all 69 parts, which is getting pretty hard, you may want to get an upgrade kit from classicautoair.com.  They make everything including the hard lines.
Rolling_Thunder
in all honesty --  no...    B-body to B-body only - and even those are year to year differences.
cowboy4x4n
Thanks guys that helps ill skip it
