Door hinge pin kit
Started by Dino, April 08, 2013, 09:36:25 AM
Well it took a while but the driver's side door is finally starting to get loose.  The door still shuts fine but I can wiggle it up and down a bit when the door's half open so time for new pins and bushings.
I know a ton of different kits work but before I grab this, can anyone confirm they work?
http://www.napaonline.com/Catalog/Result.aspx?Ne=2000000&Ntk=Keyword&Nty=1&Ntt=door+hinge+pin+kit&N=599001+101969+50020+2020008
Any other kits you guys can recommend?
I need to remove both doors to drill the holes for the power window wiring so I'm going to change the ps pins while I'm at it.
kab69440
I believe my pin/ bushing kit came from The Paddock years ago. I can't imagine the NAPA kit is much different.
I have an awesome idea for a greaseable bushing and roller bearing upgrade, but no money to put it into action. Seems like a door hinge would last forever engineered that way regardless of the weight it was supporting.
Imagination was given to man to compensate him for what he is not;  a sense of humor to console him for what he is.      Francis Bacon
WANT TO BUY:
Looking for a CD by  'The Sub-Mersians'  entitled "Raw Love Songs From My Garage To Your Bedroom"
Also, any of the various surf-revival compilation albums this band has contributed to.
Thank you,    Kenny
Jesus drove a Honda. He wasn't proud of it, though...
John 12: 49     "...for I did not speak of my own Accord."
HOTROD
Yep I used it, top hinge no problem but don`t drill out the lower !!
a friend of mine is giving me a nother lower! :brickwall:
What the Hell-Dumass !
Quote from: kab69440 on April 08, 2013, 06:05:23 PM
yep got a pin kit from the paddock too  , never used the pins for the lower hinges , before i even got round to using them  , saw  2 NOS lower hinges  for sale & bought them  :yesnod:  , so just fitted new pins to the top ,
kab69440
Quote from: HOTROD on April 08, 2013, 10:59:18 PM
What was the problem on the lower? Both of mine work fine.
WANT TO BUY:
Thank you,    Kenny
Isn't the idea with the new pin kits to drill out both upper and lower and install a bushing on each?  I know the originals don't have bushings on the lower but to make a generic kit it makes sense that you'd have to modify that part.  I don't minnd either, I need the doors to be tight on the hinges, I don't care if there's a non stock bushing in there.
Btw, does the paddock still exist?
Charger-Bodie
Quote from: Dino on April 09, 2013, 06:37:43 AM
Dirk,
Paddock is gone.....  Mega parts has a really nice pair of kits. The top ones have bushings and commonly they just pop out and the new one slide right in. The bottom ones arent  too bad. Have to either drill it and clearance the two halves for the bushings lips or get the kit with the oversized pin which dissent use bushings.
Quote from: 1HotDaytona on April 09, 2013, 07:19:31 AM
Dirk,
I just looked at the pin kit.  http://www.megapartsusa.com/proddetail.asp?prod=114%2D280004
If that's for one door then it's about twice the cost of other kits but if this is the kit to get the I'll suck it up.  So how does this work?  Two bushings for the top hinge and two for the lower where before there was none?
Seems easy enough.  (famous last words  :icon_smile_big: )
Dino, that's for one door....but I have never had to re-pin any of my upper hinges....just the lowers
Bryan
Already been done long ago
http://www.superbirdbob.com/acme-products/rebuilt-door-hinges/
Quote from: A383Wing on April 09, 2013, 12:50:39 PM
Bryan
That's interesting.  I've got a few minutes tomorrow so I'll see what's going on with the hinges.  Thanks for the tip.
kab69440
Quote from: A383Wing on April 09, 2013, 12:54:01 PM
I don't see any bearings in that setup.
WANT TO BUY:
Thank you,    Kenny
HOTROD
On my lower I drilled out the hole right (to big) try ed to put a bushing in,it will not fit between the spaces on the hinge !
Patronus
^ I hear ya. I tried like hell and finally got em in there, 2 weeks later the head of the bushing got shaved to nothing. Sucks, but you may want to clearance that flange into the hinge. What's the deal with bearings in the hinge? Anyone making them yet?
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
Wing it looks like you're right, the lowers are worn out but hte uppers seem fine.  They may have some play and I may put new bushings in there but yeah the lowers are the real problem.
So the megaparts kit is for one door so $15 (x2) + shipping.  Is this all that much better than the $8 (x2) napa kit that I can get down the road?
The napa description says the kit is 1 pin and 4 bushings but shows 2 pins, 1 shorter than the other, so I guess they made a mistake on the website.
I bought my kits off ebay....problem is that you have to shave some meat off each of the ears that the bushings go into for the lower hinge to make it all fit together.
Word of caution: Be careful when drilling out the lower hinge for bushing....if you go a little too big, hinge is junk and you gotta find another one. I screwed up 2 of 'em before I got the right drill size to fit bushing.
Bryan
